IWC Ingenieur 40mm Models
Using ETAs as a base to keep the price down? $6600 is still quite a bit of bank! I like the watch and would probably wait for the secondary market.
REFERENCEIW323902
CASE MATERIALstainless steel
BRACELET/STRAPstainless steel bracelet
DIAL COLOURblack
JEWELS21
PRICE$6,600
Mechanical movement
Self-winding
42-hour power reserve when fully wound
Date display with crown-activated rapid advance
Central hacking seconds
Screw-in crown
Soft-iron inner case for protection against magnetic fields
Sapphire glass, flat, antireflective coating on both sides
Water-resistant 12 bar
Case height 10 mm
Diameter 40 mm
REFERENCEIW323902
DIAL COLOURblack
JEWELS21
PRICE$6,600
Mechanical movement
Self-winding
Screw-in crown
Case height 10 mm
Diameter 40 mm
