Bremont U-2 with Blue Dial
Via Monochrome:
Bremont just released a new version of the popular U-2, now with a blue dial. That makes it sound good as well… the U-2 Blue. Previously only available with a black dial in stainless steel of black DLC coated case, which are all sold out, the new U-2 comes in stainless steel with a blue dial and a blue barrel. Technical Specification
Movement: Modified calibre BE-36AE automatic chronometer, 25 jewels, Glucydur balance, Anachron balance spring, Nivaflex 1 mainspring, 28,800 bph, 38 hour power reserve, Bremont moulded and skeletised decorated rotor, C.O.S.C chronometer tested.
Functions: Hour/minute/second, date and day at 3H.
Case: Hardened stainless steel Trip-Tick® case construction with sapphire bi-directional rotating bezel. Case diameter 43mm, lug width 22mm, protective patented anti-shock movement mount, water resistant to 10 ATM / 100 metres.
Case back: Stainless steel with integrated flat crystal, 5 stainless steel screws with polished heads.
Bezel: Patented inner bi-directional Roto-Click® bezel. Operated by crown at 4H.
Dial: Metal dial, SuperLumiNova coated numerals and hands.
Crystal: Domed anti-reflective, scratch resistant sapphire crystal.
