Tech255
Vintage pocket watch in need of tlc
I have inherited this pocket watch from grandfather but it has some problems, firstly is seems to have been overwound or possibly has a fault with the winder, also if you pull the crown out to set time it has areas where it feels like it sticks.
There is a slight dent near the quarter past marker this is stopping the front clipping on and also the glass is loose.
When you press the crown down the mechanism shows three distinct functions, the mechanism looks in good condition and untouched.
From checking a website about silver hallmarks it is 925 silver with 3 bears which seem to indicate made late 1800 to early 1900 no idea on maker although it has an S with a T inside it not sure if this is a makers mark but would like to try and find out.
What i need to do is get an idea of its value to determine if its worth spending money on to get it repaired i would kind of like to keep it if i can get it working.
I will try and load some pictures.
You do not have the required permissions to view the files attached to this post.
