- DBCooper
Raymond Weil Freelancer
Picked this up last week. Have had my eye out for a decent deal and one finally came along I can live with. As usual I will post the particulars and some pics.
The packaging.
Case diameter is 42mm with a height of 10.2mm and a 22mm lug width. 100m water resistant.
Another simple dial with 3 hands, just the way I like them. The silver dial has a nice looking texture around the outside portion of the dial. Polished hour markers that are easy to see. I think the extended date window works on this one. Sapphire crystal with antiglare treatment.
This one has an ETA 2824. I'm not sure but I think RW is another company that also uses Sellita. My initial accuracy check over 3 days was +22 secs. Nothing to brag about but not too bad either. Seems to be a pattern with ETA running a little fast out of the box. Screwed down case back with sapphire crystal.
The push/pull crown is signed. The jubilee style bracelet is signed at the dual deployant clasp and uses screw links. No half links on this one. It's a good thing I like them a little on the loose side or I would have a problem.
I like the lume on this one.
A couple of wristshots. This 42mm behemoth feels pretty big and heavy after wearing 38 and 39mms. Looks good to me though.
ISSUES:
The only issues I have at this point are no half links on the bracelet and the crown isn't that easy to wind and it's too big for my crown winder.
The packaging.
ISSUES:
Sam
